Date/Time: Fri, 11 Sep 2026 20:12:13 +0000
Keyboard Shortcuts for Chart Periods volume not working
View Count: 561
| [2024-11-30 12:19:30] |
| User173763 - Posts: 14 |
Hi, I am on Sierra version 2661. When i press 1 followed by 'm' or anything relevant the chart doesn't change to a 1 minute bar. Similar for volume bars 200 'v'. The chart is activated and i have pressed Escape before. Managed to partially overcome this by going to Global Settings >> Customize Keyboard Shortcuts >> Bar periods and configured shortcut keys for some time periods i am interested in. Still i would like to have the ability to change to any time period by using the shortkey as defined on the documentation and off-course switch between volume bars which i can't do in any way now. Thanks |
| [2024-12-02 17:25:54] |
| John - SC Support - Posts: 47853 |
There is no reason why this should not be working. Make sure you have the chart selected before entering the keyboard commands. Left-Click in the graphics area of the chart to ensure that chart is active. Then enter the following keystrokes 1 m <enter> Do not forget to use the Enter key at the end to make the change to a 1 minute per bar period. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-12-02 19:54:16] |
You are right Missed the <enter> for some reason Appreciated |
