Date/Time: Fri, 27 Dec 2024 17:13:05 +0000
With Teton Routing and Denali Feed, are all brokers equally fast?
View Count: 117
[2024-11-30 10:41:05] |
ATEX - Posts: 12 |
Hi, If I'm using Teton order routing and the Denali data feed, does it matter what broker I'm using in terms of execution speed? Is there a difference between using a 'broker' or 'clearing firm' on this list: Sierra Chart Teton Futures Order Routing: Setup Instructions Regards, A |
[2024-11-30 17:40:31] |
Sierra_Chart Engineering - Posts: 17677 |
No it does not matter.
