Date/Time: Wed, 04 Dec 2024 08:40:08 +0000
Message Rithmic
View Count: 55
[2024-11-30 10:25:29] |
User914407 - Posts: 47 |
Bonjour, Je reçois le message suivant : Rithmic's history plant guardian has observed that your user id, PP-005887, has requested historical market data resulting in 20464146144 bytes transmitted to your computers since Rithmic's systems most recent scheduled reboot. You are approaching your weekly allotment of historical market data Once you exhaust your allotment of data for the week your access to historical market data will suspended for the remainder of the week. Thanks Rithmic's History Plant Guardian Où puis-je résoudre le pb ? Merci |
[2024-12-02 17:20:11] |
John - SC Support - Posts: 36442 |
You are getting your data from Rithmic, and they are stating that you are approaching your weekly limit of historical data that you can get from them. You would need to ask your broker about this limitation with Rithmic and see if there is an option that you can pay for to get more data. The other option would be to use our Denali Exchange Data Feed for your data, as we do not have this kind of limitation on historical data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-02 17:24:13] |
Quelles sont les options à modifier sur SC pour limiter l'historique ?
[2024-12-02 18:05:57] |
From Google Translate: What are the options to change on SC to limit the history?
You need to limit the number of days of data for which you are making a request for data. Refer to the following: Data/Trade Service Settings: Maximum Historical Intraday Days to Download (Global Settings >> Data/Trade Service Settings >> Common Settings) Chart Settings: Days to Load for Intraday Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-02 18:09:02] |
Quels sont les reglages conseillés pour le NQ, SP500 et le DAX afin que cela ne soit pas trop ralenti ?
[2024-12-02 18:13:45] |
What are the recommended settings for the NQ, SP500 and DAX so that it is not too slow?
We really can not answer this. It depends on what you need for your charting. It is generally best to limit the data to only what you need. So if you only need 1 day of data, then only load 1 day of data. The same if you need 1 week or 1 year or 10 years. Just keep as little data as you can for what you need. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
