Date/Time: Wed, 27 Nov 2024 14:32:21 +0000
Narrow Range Bar study Subgraph setting
View Count: 1085
[2014-09-11 13:59:51]
User17064 - Posts: 70
Hi SC support,
I am useing "Narrow Range Bar"study, and in Subgraphs, the default setting for the Draw style is Color Bar. I change it to Point(would like to show the dot on the bar), but after I select that, the chart become strange, all the bar chart only show in the low 1/3 part of screen.
Is there any way to show dot on those narrow range bar?
[2014-09-11 18:58:50]
Try using Point on High for the Draw Style.
[2014-09-12 04:40:03]
Thanks a lot! It solved!
