Date/Time: Wed, 16 Sep 2026 06:58:23 +0000
Question on Nifty contract size - NIFTY
View Count: 591
| [2024-11-29 21:31:24] |
| User100139 - Posts: 5 |
Thanks a lot. Fixed the latter issue. Just one more thing on this. I use NIFTY and BANKNIFTY primarily. Unlike the ES Or CL, these indices have a contract size of 75/30 respectively. So the volume represented in FP is 75/30 times more than the actual transaction of contracts. How can I reduce this number in the display. In the current setup, the Bid X Ask becomes quite wide because of this relatively large volume. Thanks Date Time Of Last Edit: 2024-11-30 03:30:46
| [2024-12-02 17:02:48] |
| John - SC Support - Posts: 47903 |
There are a few options. 1. Use the "Volume/Open Interest Multiplier". Refer to the following: Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) 2. On the Numbers Bars study there is an option for "Volume Display Multiplier" that can shift the data being displayed without affecting the actual number (this is different from the above). Refer to the following: Numbers Bars: Volume Display Multiplier For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
