Date/Time: Fri, 27 Dec 2024 11:20:02 +0000
Bid/Ask Difference volume profile becomes black when chart window is maximized
View Count: 150
[2024-11-29 16:12:24]
sean3000 - Posts: 60
I have a detached chart with a volume profile using Ask Volume - Bid Volume for drawing and Difference of Bid And Ask Volume Coloring for coloring.
This is how it normally looks (pink and blue bars):
https://www.sierrachart.com/image.php?Image=1732896437177.png
This is how it looks when I maximize the window (black bars):
https://www.sierrachart.com/image.php?Image=1732896636395.png
[2024-11-29 21:18:08]
Sierra_Chart Engineering - Posts: 17672
Check the Volume Bar Outline color setting:
Volume By Price Study: Volume Bars Outline and Fill Colors (SG8)
You might also need to adjust the Ticks Per Volume Bar:
Volume By Price Study: Ticks Per Volume Bar
[2024-11-29 21:44:02]
I changed the Volume Bar Outline and Fill Color to white/white and the issue remains. I have Draw Outline When Coloring Bid Volume and Ask Volume set to "No" so I don't think this would be the cause.
I tried a number of different tick sizes and the issue is still there.
The issue also occurs when slightly increasing the height of the chart window.
[2024-11-29 21:48:04]
I just updated to 2712 and the issue has gone away.
[2024-11-29 21:59:03]
This is not a version specific issue. That is not possible. There have been no changes related to this. Are you using OpenGL?
[2024-11-30 01:18:29]
Yes, I am using OpenGL.
[2024-12-02 21:11:12]
The issue is appearing again and a different chart is now flickering/flashing.
I have seen the recommendations to disable OpenGL, but I prefer not to do that. Sierra Chart performs noticeably better with OpenGL enabled, and my charts are 10x faster with OpenGL on.
I rebuilt the charts and the issue went away, so it was possibly due to a study configuration.
Also, I usually have the title bar hidden, which can apparently create issues that are Windows-related and beyond the control of Sierra Chart.
I understand OpenGL issues are likely outside the scope of support but I wanted to provide an update for anybody else who has a similar problem.
