Date/Time: Fri, 27 Dec 2024 14:08:58 +0000
[User Discussion] - Sierra - simulation mode - market order not filled
View Count: 91
[2024-11-29 14:18:35] |
stefkovic.m28 - Posts: 18 |
Hello, I have started my simulation mode in Sierra with DTC for ESZ4.CME, but every market order is not filled also in case, that server schow us its working. The same I have tried with Nasdaq100 and there was order filled OK. Do you know why I canĀ“t open an order, or the order can be not filled? I have attached my trade window too. thanks Date Time Of Last Edit: 2024-11-29 14:21:28
SP500.CME.JPG / V - Attached On 2024-11-29 14:18:22 UTC - Size: 38.75 KB - 28 views |
[2024-11-29 22:07:42] |
Sierra_Chart Engineering - Posts: 17672 |
Refer to: Trade Simulation: Why Fill and Order Prices Can Be Wrong or Unexpected / Orders Do Not Fill When Expected Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-29 22:08:22
