Date/Time: Wed, 27 Nov 2024 14:22:01 +0000
Is Tick bar ?
View Count: 899
[2014-09-11 13:53:02] |
User120827 - Posts: 77 |
Which chart type is like tick charts in other programs ? Volume or trades per bar ? I do not remember which one is most like tick chart. |
[2014-09-11 17:43:58] |
The Bar Period Type you need to use in Sierra Chart is "Number of Trades Per Bar". This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-11 17:44:17
