Date/Time: Wed, 05 Feb 2025 17:05:44 +0000
How to reverse the Activity Log
View Count: 156
[2024-11-28 10:17:59]
SomeRandomUser - Posts: 123
Is there a sort function or some way to see the total P/L and most recent transactions on top, and in descending order, rather than at the bottom?
Currently I have to scroll to the bottom of a long list.
This is on the "Trades" tab.
Thank you.
Date Time Of Last Edit: 2024-11-29 00:20:51
[2024-11-28 18:47:10]
Sierra_Chart Engineering - Posts: 18285
What is the exact tab of the Trade Activity Log you are referring to?
[2024-11-29 00:20:25]
"Trades"
[2024-12-02 16:22:19]
John - SC Support - Posts: 37753
On the Trade Activity Log is an option for "Edit >> Descending Display Order". The Trades tab will follow this option, just keep in mind that the Trades tab is ordered by symbol and trading account, then by date.
[2024-12-03 00:13:18]
Thanks for getting back to me.
"Edit->Descending Display Order" doesn't work.
I have 5 symbols up, all on the same account, and they don't sort within themselves. Clicking On "Descending Display Order" puts a check mark into the box but does not sort anything in the Trades tab.
Also:
- Clicking on "Refresh Log" does nothing.
- Filtering for only one symbol does nothing.
- Going into Display Settings and hitting "Apply All" does nothing.
The "Descending Display Order" seems to be totally nonfunctional.
Date Time Of Last Edit: 2024-12-03 00:14:00
[2024-12-03 15:59:12]
If you have the option for "Edit >> Flat to Flat Display for Trades List" enabled, then the "Descending Display Order" will not cause any changes in the Trades tab. We think this may be the reason for what you are seeing.
[2024-12-03 16:11:06]
100%. That's what it was. Thanks for the help.
