Date/Time: Wed, 27 Nov 2024 14:26:21 +0000
Infinity brokerage and Sierra Chart
View Count: 1239
[2014-09-11 12:38:32] |
User76044 - Posts: 11 |
Hi I see Infinity Futures offer SierraChart for free, what package do you get if you use them, is it Sierra Package 3 or 5? I am mainly interested in historical data and whether you can you draw a volume profile with their version? Can I execute trades with the Sierra DOM with InfinityFutures rather than their DOM. Do you support Server side OCO's when executing trades with Infinity Brokerage through the Sierra DOM? Is Volume and Delta (Bid/Ask) data reliable from InfinityFutures? Thanks, Ben Date Time Of Last Edit: 2014-09-11 12:48:45
[2014-09-11 16:41:11] |
In this case it will be Sierra Chart service package 3. With Sierra Chart service package 3 you can add the Volume by Price study to a chart but not draw it using a drawing tool. Can I execute trades with the Sierra DOM with InfinityFutures rather than their DOM. No. This will require using your own Sierra Chart account and paying for Sierra Chart directly.Do you support Server side OCO's when executing trades with Infinity Brokerage through the Sierra DOM? Is Volume and Delta (Bid/Ask) data reliable from InfinityFutures? You will need to contact Infinity Futures about this.
