Date/Time: Tue, 22 Apr 2025 23:27:19 +0000
ACSIL Request: ability to query # of OCO groups defined
View Count: 147
[2024-11-27 12:13:11] |
ycomp - Posts: 323 |
Hello, can you add an ACSIL function or variable that returns the # of OCO Groups defined on the chart?
[2024-12-19 15:13:49] |
Sierra_Chart Engineering - Posts: 19306 |
Yes this has been added: sc. GetNumAttachedOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
