Date/Time: Fri, 27 Dec 2024 07:48:37 +0000
TAL Display Settings
View Count: 133
[2024-11-27 05:41:52]
User688525 - Posts: 273
Hello Sierra Chart,
Is it possible to set the default "From Time" and "To Time" values in the TAL Display Settings?
I have read through the Trade Activity Log documentation and don't see an option for this (https://www.sierrachart.com/index.php?l=doc/TradeActivityLog.php#UnderstandingAndSettingTheStartDateTimeForATradesList)?
Thank you
Private File
Private File
[2024-11-27 16:02:27]
John - SC Support - Posts: 36873
There is not an option to set the From/To Times to specific default values.
The only option that comes close to this is the selection for "Set to Today's Date", which sets the times to 00:00:00 and 23:59:59. Refer to the following:
Trade Activity Log: Common Instructions to Set Trade Activity Log Display Settings
[2024-11-27 17:57:52]
Hi John,
Thank you for confirming.
[2024-11-29 08:32:34]
Sierra_Chart Engineering - Posts: 17672
These values do not change unless you change them. So just set them to whatever you want. If they are changed, then make sure Risk Manager Mode is disabled:
Trade Account and Risk Management: Setting Sierra Chart to Risk Manager Mode
Date Time Of Last Edit: 2024-11-29 08:32:49
[2024-11-30 06:45:31]
Noted.
