Date/Time: Wed, 27 Nov 2024 13:07:51 +0000
Spreadsheet help
View Count: 918
[2014-09-11 06:33:45] |
User20702 - Posts: 13 |
Hello When I have my chart set to 3T Renko bars with Heikin-Ashi My attached spreadsheet is priced in 11 digit decimals can it be set to .25 increments? I have looked through all the documentation I can find on your site, I can not seem to figure out how to place a limit order at the price I want it submitted through the dom directly from the spreadsheet. What I want to do is when my buy signal goes off I want to send a signal to buy @ 1998.25 for example. Also is there any other help I can obtain for the spread sheet that you know of? Thanks Dave |
[2014-09-11 09:04:30] |
What you need to do is add the Round Price Bars to Tick Size study to the chart to do what you want. For help with using limit orders from the Spreadsheet System for Trading study, refer to: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#BuyEntryLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-11 09:04:58
