Date/Time: Wed, 27 Nov 2024 14:43:30 +0000
number bar and number bar counting space mis match
View Count: 1229
[2014-09-11 06:05:36]
User38813 - Posts: 20
sir i am not able adjust space between number chart and number bar calculations
[img]http://imagizer.imageshack.com/img742/2128/Ko5zP9.png[/img]
[2014-09-11 06:32:36]
When we click on that link it says the image is Not Found.
[2014-09-11 06:44:55]
http://imagizer.imageshack.com/img673/8741/XPadI3.png
http://imagizer.imageshack.com/img908/9814/oTMsaC.png
http://imagizer.imageshack.com/img908/9814/oTMsaC.th.png
Date Time Of Last Edit: 2014-09-11 08:59:32
[2014-09-11 18:04:36]
Do not add any image tags like you are. It is unnecessary and causes us problems to look at images. Also only post the minimum number of images needed. When there is too much here, it causes us to defer the support request until later on when we have more time to look at it.
Make sure the Chart Region setting for the Numbers Bars Calculated Values study is set to 2. This is in the Study Settings window for the study:
http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies
Once you have done that, you can adjust the height of that chart region by following the instructions here:
http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartWindowandRegions
Date Time Of Last Edit: 2014-09-11 18:06:50
