Date/Time: Fri, 22 Nov 2024 07:32:23 +0000
pitchfork and other lines keep moving
View Count: 1807
[2013-05-09 14:12:14]
HamSandwich - Posts: 5
whenever I adjust the X or Y axis or sometimes when price is moving this causes my pitchforks and other lines to readjust. This is not an optical illusion as the line will move up or down relative to a price bar and completely alter the context of the pitchfork. Is this a glitch in the program or is there a setting I can adjust that will make the line stationary relative to their original placement?
PS the 3 anchor points for a PF will not move- just the shape of the lines further down the price chart.
[2013-05-10 03:18:11]
For an understanding why this happens, refer to:
http://www.sierrachart.com/index.php?l=doc/helpdetails34.html
And also refer to Secondary Anchor Point:
http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Pitchfork
