Date/Time: Fri, 27 Dec 2024 19:49:01 +0000
Point of Control (Footprint)
View Count: 189
[2024-11-23 14:18:20]
User760022 - Posts: 11
I'd like to add the Point of Control on my Footprint Chart ($ES)(5mins Chart).
I was wondering if you could help me figure that out/input the setting for POC.
Thank you very much.
Regards
Haseeb
[2024-11-25 14:25:36]
John - SC Support - Posts: 36883
Refer to the following:
Numbers Bars: Highlight Point Of Control In
Or you could use a different study, such as the "Volume Point of Control for Bars". Refer to the following:
[2024-11-30 14:07:49]
I have activated but for some reason I don't see any POC on each bar.
I was wondering if you could help.
Thanks/Regards
Haseeb
imageScreenshot 2024-11-30 at 9.06.42 AM.png / V - Attached On 2024-11-30 14:06:57 UTC - Size: 177.3 KB - 37 views
[2024-11-30 18:36:31]
Sierra_Chart Engineering - Posts: 17678
We need to know exactly how these inputs are set:
Numbers Bars: Point Of Control Highlight Color
[2024-12-03 01:11:55]
I have attached a screenshot.
Let me know, if you are able to see it.
Thank you very much
Haseeb
imageScreenshot 2024-12-02 at 8.10.56 PM.png / V - Attached On 2024-12-03 01:11:11 UTC - Size: 257.78 KB - 20 views
[2024-12-03 03:58:37]
User688525 - Posts: 273
Go to the Numbers Bars "Settings and Inputs" tab and scroll down about halfway to the Point Of Control options (Highlight Point Of Control, Point Of Control Highlight Color, Point Of Control Highlight Width). Make sure these options are configured correctly.
[2024-12-03 13:15:32]
I am all set. I want to really thank you for your help on this. I really appreciate it and love using Sierra Chart (Footprint).
Thanks/Regards
Haseeb🥂
