Date/Time: Fri, 20 Sep 2024 03:42:59 +0000
Connection
View Count: 881
[2014-09-10 19:16:21] |
User69287 - Posts: 9 |
Hi, I would like to know if is possible connect my Interactivebrokers account with Sierra Chart Real-Time and Historical Exchange Data Feed? I have no money now on IB account. Is there something like minimum deposit? I just need it for papertrading. Thx
[2014-09-10 19:49:51] |
Did you need futures data?
[2014-09-10 21:13:28] |
yes
[2014-09-11 03:57:28] |
Most likely you will find it too expensive. You need to refer to this information here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-11 03:57:41
