Date/Time: Thu, 21 Nov 2024 09:37:08 +0000
Sierra Chart Instance Crashing
View Count: 18
[2024-11-21 03:21:40] |
Maxpowers2k - Posts: 21 |
Thanks for looking I have an issue where Sierra Chart Crashes about once or twice a week. I have 3 Instances running 24/7 and reboot the computer once a week. The "Main" instance Crashes on occasion. Is there a way I can share crash Data to possibly investigate? |
[2024-11-21 04:07:55] |
Sierra_Chart Engineering - Posts: 17133 |
First update Sierra Chart to the latest prerelease: Software Download: Fast Update Are you using the Chat functionality (File >> Open Chat Window)? Also refer to help topic 17: https://www.sierrachart.com/index.php?page=doc/helpdetails17.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-21 04:08:12
