Date/Time: Wed, 27 Nov 2024 14:24:07 +0000
Add Charts..
View Count: 899
[2014-09-10 18:03:11]
User83963 - Posts: 18
Purchased the data feed for the S&P indices. How do I add the 1 hour, Daily, and Weekly, Charts? Thank you..
[2014-09-10 20:12:15]
Make sure you have Global Settings >> Data/Trade Service Settings >>Allow Support for Sierra Chart Data Feeds enabled.
Select File >> Find Symbol>> Indexes. Select a particular S&P Indices symbol that you want and then open either a Historical or Intraday chart.
[2014-09-11 21:00:42]
Everytime I open a chart as detailed above it is a daily chart. Would you tell me how to change or open a 1hr. thank you..
[2014-09-11 23:50:16]
Select File >> Find Symbol >> [select symbol] >> Open Intraday Chart.
If you do not see the chart that you want, then post an image of the chart by following these instructions:
