Date/Time: Thu, 21 Nov 2024 10:09:36 +0000
Is it possible to get POC to plot on top of Value in VbP?
View Count: 30
[2024-11-21 02:35:02] |
cmet - Posts: 549 |
This may be a dumb question but... I'm using Volume by Price with the POC,VAH, VAL, VWAP Lines Only draw mode. I want to simply plot a box for the value area using Fill Rectangle bottom/Fill Rectangle top. I also want to plot the POC as a dash. All of this works fine BUT, the Value area is drawn on top of the POC so the POC is not visible. I don't want to use transparent rectangles. Is there a way to get the POC to show up on top of Value area? Seems that's how it should be? (VWAP by the way plots on top of the Value area) Date Time Of Last Edit: 2024-11-21 02:38:29
[2024-11-21 09:24:56] |
User431178 - Posts: 537 |
All of this works fine BUT, the Value area is drawn on top of the POC so the POC is not visi Being as POC is SG1, it is drawn first, followed by VAH, then VAL and VWAP. I want to simply plot a box for the value area using Fill Rectangle bottom/Fill Rectangle top. Use this study to plot the box Study Subgraphs Reference Example chart attached. Date Time Of Last Edit: 2024-11-21 09:25:10
VBP-ValueBox.Cht - Attached On 2024-11-21 09:24:50 UTC - Size: 4.52 KB - 2 views |
