Date/Time: Tue, 03 Dec 2024 16:44:53 +0000
Market Profile
View Count: 60
[2024-11-21 00:20:32]
User935820 - Posts: 2
How can I overlap the market and volume profile. And just have the volume profile VAH and VAL and VPOC. And how can I set both to just New York session 9:30 a.m. est - 4 p.m. est?
[2024-11-21 14:42:57]
John - SC Support - Posts: 36415
To get the VAH, VAL and VPOC for a Volume Profile displayed on a TPO chart, you would need to use a separate chart for the same symbol to setup either a Volume by Price profile with the Draw Mode set to "POC, VAL, VAH, VWAP Lines Only" and then overlay that to the TPO chart using the "Study/Price Overlay". Or you can do the same thing but use the "Volume Value Area Lines" study instead of the Volume by Price.
To set the TPO to be a certain time period, set the Session Times to have the main session be the times you want and then do not use an Evening session.
We are not sure what you are looking for in terms of "overlap", but we think the answers above should cover it.
