Date/Time: Wed, 27 Nov 2024 12:21:07 +0000
Chart Questions.
View Count: 960
[2014-09-10 18:00:04] |
User83963 - Posts: 18 |
Purchased the data feed for the S&P indices was able to load the 10 min chart. How do I increase the candlestick width? How do I add 5, 20, and 50 PMA average lines? Thank you.
[2014-09-10 20:02:06] |
You can increase the candlestick width through Graphics Settings. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html To add studies to charts, refer to the steps here: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
