Date/Time: Thu, 21 Nov 2024 13:33:01 +0000
[User Discussion] - Pivot points
View Count: 21
[2024-11-20 17:28:35]
User700382 - Posts: 12
Hello!
I am using sierra chart for my big picture analysis and prefer it most over the other platforms, but have noticed that on tradingview that same study ( pivot points ) shows completely different levels. How can I get same levels of pivot points in sierra chart. If this helps, I chose "Pivot Points Traditional" type of it in tradingview. I think the calculation method is just different for them which creates the difference.
Thank you for your time and help in advance :)
imageScreenshot 2024-11-20 181544.png / V - Attached On 2024-11-20 17:24:05 UTC - Size: 89.9 KB - 6 views
imageScreenshot 2024-11-20 181606.png / V - Attached On 2024-11-20 17:24:14 UTC - Size: 72.54 KB - 7 views
[2024-11-20 17:42:35]
John - SC Support - Posts: 36174
We can not help with this. All of our Pivot Point calculations are specified in the following link:
Pivot Points: Formula Types
You would need to compare what we specify with how Trading View does their calculations.
We have set this thread as a "User Discussion", as there may be other users that know the differences in the system and can give you information.
