Date/Time: Wed, 27 Nov 2024 12:25:02 +0000
CTS historical daily chart data
View Count: 925
[2014-09-10 16:49:37] |
bwalks123 - Posts: 122 |
I am running a CTS demo and have a historical daily chart up but it looks like CTS is only providing about 4 yrs worth of daily bar data, all of the data before 2010 is jumpy and not filled in correctly? I have continuous futures contract set to "volume based rollover, back adjusted" is that correct? I would like to see about 10 yrs worth of daily bars if possible using CTS.
[2014-09-10 17:06:41] |
What symbol?
[2014-09-10 17:21:14] |
ZN Z14 Data seems to stop April of 2009, that's when the data becomes jittery |
[2014-09-10 20:15:40] |
Re-download the data following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading I would like to see about 10 yrs worth of daily bars if possible using CTS. This is not available. It will be closer to five years.Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
