Date/Time: Wed, 27 Nov 2024 12:28:09 +0000
Volume Value Area Lines
View Count: 1126
[2014-09-10 16:43:48] |
skytrader1 - Posts: 2 |
Hello. I wanna use the VPOC with Standard Deviation lines (the same as in study Volume Weighted Average Price (VWAP) with Standard Deviation Lines), but all I found is the Volume Value Area Lines study, which provides only the 1 standard deviation of VPOC (value area). How can see more than 1 s/d lines of the VPOC? Thanks. |
[2014-09-10 17:21:29] |
The Value Area is not a standard deviation of the Point of Control. For the calculation method, refer to: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#IncorrectValues If you want to use different Value Area percentages, simply add more instances of the Volume Value Area Lines study to the chart and change the percentage. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-10 18:17:22] |
Yeah, more instances should work, thanks. That sad I haven't thought of it, looks like I'm getting stupider with years...
