Date/Time: Tue, 03 Dec 2024 17:51:50 +0000
Remove Daily Line
View Count: 72
[2024-11-20 03:54:07] |
User296553 - Posts: 17 |
I've been trying to remove the daily line close, I'd made sure that there's no indicator present, where can I locate this setting so I can turn it off? This is Vix with 240mins, |
[2024-11-20 16:32:30] |
John - SC Support - Posts: 36426 |
If it is not a study, then it would need to be the Vertical Grid. Refer to the following: Chart Settings: Show Vertical Grid (Chart >> Chart Settings >> Grid >> Show Vertical Grid menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
