Date/Time: Wed, 27 Nov 2024 12:23:14 +0000
[User Discussion] - Smart Trade vs FastSmart vs FastTrade?
View Count: 1005
[2014-09-10 16:42:22] |
bwalks123 - Posts: 122 |
I am running a CTS demo account and am playing around scalping a few ticks off of the DOM, what is the difference between Smart Trade vs FastSmart vs FastTrade? Is one faster than the other, more reliable or accurate bid/ask volume? Which is the most demanding on CPU?
[2014-09-10 17:06:57] |
These are documented here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions None of these make any difference at all with CPU usage. If you have further questions about this, you must contact CTS. We will not know the answer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
