Date/Time: Thu, 21 Nov 2024 12:29:19 +0000
ACSIL Notepad++ error
View Count: 44
[2024-11-20 03:25:44]
User745789 - Posts: 310
I am trying to follow the tutorial here Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function
I am unable to open Notepad++ at Step 4. Please see error in attached image. However, I see that the application "notepad++" exists in the specified folder
How do I proceed? Can I just manually open notepad++ from the folder and start my work?
image2024-11-20 11_20_10-Message Log.png / V - Attached On 2024-11-20 03:22:22 UTC - Size: 8.34 KB - 12 views
[2024-11-20 16:24:27]
John - SC Support - Posts: 36174
Make sure that the path to that executable is correct. It is set in "Global Settings >> General Settings >> Paths >> Text Editor Path and Filename". Refer to the following:
General Settings Window: Text Editor Path and Filename (Global Settings >> General Settings >> Paths >> Files and Folder Paths)
You can just open Notepad++ separately, you do not need to do it through Sierra Chart, that is just a convenience. Also, you can use whatever editor you like, you do not need to use Notepad++.
