Date/Time: Wed, 27 Nov 2024 12:29:55 +0000
How to stop drawings from attaching/snapping to bars
View Count: 965
[2014-09-10 13:25:44] |
User13931 - Posts: 2 |
Hi.. my drawings seem to want to attach to bars and also my global cursor will only move to bars... I dont have auto snap turned on.. I would like to be able to draw lines or objects anywhere on the chart but they all want to anchor to a bar... what do I have to do to be able to draw anywhere? thanks for your time...
[2014-09-10 17:31:16] |
What you want is not supported and never will be.
