Date/Time: Thu, 21 Nov 2024 13:16:39 +0000
Buttons to change Accounts
View Count: 32
[2024-11-18 12:47:57] |
User137622 - Posts: 6 |
Is it possible to add Buttons to Switch my trading Accounts e.g. Topstep, Dorman, etc. without selecting the data Trade service manually and select Rithmic Direct DTC or Teton CME Order routing everytime i want to switch? |
[2024-11-18 16:23:22] |
John - SC Support - Posts: 36174 |
You can setup configurations within the "Data/Trade Service Settings to quickly change between different settings. Refer to the following: Data/Trade Service Settings: Saved DTS Configuration (Global Settings >> Data/Trade Service Settings >> Main Settings) But we really recommend using multiple installations of Sierra Chart to access different trading services so you are always connected to those services and you do not need to worry about your orders. You can get the data from our Denali Exchange Data Feed to 3 different installations on the same computer. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
