Date/Time: Thu, 21 Nov 2024 13:23:22 +0000
Charting- Study Subgraph Reference
View Count: 43
[2024-11-18 01:44:18] |
User841161 - Posts: 221 |
I am using the Study Subgraphs Reference-the values are correct as you can see on the y axis 5956.5 and 5966.5 but for some reason are not graphing in the right location in chart region 1 as soon on attached picture.
11-17-24.PNG / V - Attached On 2024-11-18 01:44:09 UTC - Size: 101.46 KB - 21 views |
[2024-11-18 16:14:42] |
John - SC Support - Posts: 36174 |
The default scale for the "Study Subgraphs Reference" is "Independent". Change the scale to either "Automatic" or "Same as Region" and your issue should be fixed. Refer to the following: Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
