Date/Time: Thu, 21 Nov 2024 13:21:29 +0000
What do I need to get started
View Count: 83
[2024-11-17 09:08:52] |
User491195 - Posts: 1 |
I am a non-professional trader with an AMP account. I only trade the ES and currently use CQG data and Quantower. I want to dump CQG. Can I use the service package 3 and Denali data for a total of $38.50 per month or do I need to get the service package 10? Also, is there anything else I need to get to use Sierra charts with the Denali data feed? Thanks
[2024-11-18 15:31:38] |
John - SC Support - Posts: 36174 |
You need to be on Package 10. The "Base" packages do not allow you to get real-time data or to connect to trading accounts. Refer to the following: Description of Service Packages and Pricing: Integrated Packages You are currently on Package 10, so you are fine in this respect right now. We see that you are already setup with the data for the CME exchange, so that is all good as well. The last thing you need to deal with is whether you are going to continue to use CQG for your order routing or if you want to change to our Teton Order Routing Service. Refer to the following for the information on our Teton Order Routing Service: Sierra Chart Teton Futures Order Routing If you want to use our Teton Order Routing Service, then follow the instructions on that page. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
