Date/Time: Tue, 04 Nov 2025 08:38:39 +0000
[Programming Help] - Graphics.DrawPolygon with OpenGL enabled only draws polygons with less than 4 points
View Count: 297
|   [2024-11-17 05:16:03]     |
| User806065 - Posts: 2 |
                Hi, I had to enabled OpenGL in order for my project to render properly because I was facing issues with the GraphicsBrush not resetting properly. However, once OpenGL is enabled, the DrawPolygon function will no longer work for polygons with more than 4 points. It's very frustrating to work with. If I have OpenGL disabled, then my shapes are rendered properly, but I have no way of changing the brush. If I have OpenGL enabled, my shapes don't render at all, but I've confirmed that the brush changes correctly. void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc)
{ n_ACSIL::s_GraphicsBrush GraphicsBrush; GraphicsBrush.m_BrushType = n_ACSIL::s_GraphicsBrush::BRUSH_TYPE_SOLID; GraphicsBrush.m_BrushColor.SetColorValue(COLOR_BLUE); sc.Graphics.SetBrush(GraphicsBrush); n_ACSIL::s_GraphicsPen GraphicsPen; GraphicsPen.m_PenStyle = n_ACSIL::s_GraphicsPen::e_PenStyle::PEN_STYLE_SOLID; GraphicsPen.m_Width = 2; GraphicsPen.m_PenColor.SetColorValue(COLOR_BLUE); sc.Graphics.SetPen(GraphicsPen); n_ACSIL::s_GraphicsPoint polygon1[4]; n_ACSIL::s_GraphicsPoint polygon2[5]; // only plots polygons with 4 points or less polygon1[0].X = 0; polygon1[0].Y = 0; polygon1[1].X = 100; polygon1[1].Y = 0; polygon1[2].X = 100; polygon1[2].Y = 100; polygon1[3].X = 0; polygon1[3].Y = 100; polygon2[0].X = 100; polygon2[0].Y = 100; polygon2[1].X = 200; polygon2[1].Y = 100; polygon2[2].X = 200; polygon2[2].Y = 200; polygon2[3].X = 150; polygon2[3].Y = 200; polygon2[4].X = 100; // when these lines are uncommented, the second polygon does not show up on the chart polygon2[4].Y = 250; sc.Graphics.DrawPolygon(polygon1); sc.Graphics.DrawPolygon(polygon2); sc.Graphics.ResetBrush(); sc.Graphics.ResetPen(); } I made this little snippet to test my issue. With OpenGL disabled, the five-sided polygon will render, but with OpenGL enabled it will not. Any help would be appreciated. Thank you.  |
