Date/Time: Wed, 04 Dec 2024 08:56:31 +0000
System messages during trading disconnect data feed
View Count: 69
[2024-11-17 01:00:52] |
User629461 - Posts: 179 |
How do I stop the system messages (eg low balance reminder) from popping up? It can happen right in the middle of trading and momentarily disconnects the data feed then reconnects. Charts are then temporarily frozen while historical download occurs and charts then have to reload. Very disruptive. |
[2024-11-17 03:51:14] |
Sierra_Chart Engineering - Posts: 17353 |
Fairly sure this should not happen unless there is a change with exchange authorizations: It can happen right in the middle of trading and momentarily disconnects the data feed then reconnects. Make sure you have a sufficient Services Balance, ahead of time: How do I stop the system messages (eg low balance reminder) from popping up?
Additionally, we will add an option on the web services User Control Panel to disable these notifications. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-17 03:52:07
