Date/Time: Fri, 11 Sep 2026 21:36:39 +0000
Imbalance
View Count: 552
[2024-11-15 20:38:52]
ss1776 - Posts: 29
i wanted to ask if you have a indicator that alerts when there is heavy imbalance on the dom to one side. see attached pic. if you see 20605 you will notice what i am talking about thanks
Private File
[2024-11-15 20:39:30]
John - SC Support - Posts: 47853
Is that the Market Depth data or traded Bid/Ask data?
[2024-11-15 20:45:45]
ss1776 - Posts: 29
Hi
Its traded bid/ask data
[2024-11-15 21:04:47]
Then refer to the following:
Volume at Price Threshold Alert V2
[2024-11-18 13:49:21]
ss1776 - Posts: 29
That study is based off footprpint chart correct?. can i use this study on a dom chart?
[2024-11-18 17:06:13]
The study does not require any specialized chart, meaning you do not need to have the Numbers Bars study on a chart to use the study.
We are not sure what you mean by a "dom chart". You need to have actual bars to use the study, so you can not use it on a "Trading DOM", which does not have any bars.
