Date/Time: Wed, 04 Dec 2024 09:04:23 +0000
Study: High/Low for Time Period
View Count: 99
[2024-11-15 18:09:06]
User688525 - Posts: 267
With the "High/Low for Time Period", what would be the best way to draw the line from the bar that makes the high/low instead of drawing the line from the session start time?
Thank you
[2024-11-15 19:53:38]
John - SC Support - Posts: 36442
If you set the Input of "Display High Low Incrementally", then the line is drawn from each High/Low until there is a change in the High/Low, and then it changes at that bar. This will allow you to see what you are wanting.
If you want to remove all previous lines before that bar as well, then you would need to use the Spreadsheet Study and modify the data so you can get what you want.
[2024-11-15 22:04:36]
Thank you John. I'll look into the Spreadsheet Study option for the flexibility.
