Date/Time: Thu, 21 Nov 2024 13:01:45 +0000
not receiving CBOE Indices
View Count: 140
[2024-11-15 17:24:14] |
User12089 - Posts: 361 |
not receiving CBOE Indices for the whole of 15th Nov 2024
Date Time Of Last Edit: 2024-11-15 17:24:54
[2024-11-15 19:26:51] |
John - SC Support - Posts: 36174 |
Refer to the following: US Equities/CFE Data Early Morning Weekday Carrier Maintenance Notification | Post: 400036 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-16 13:20:56] |
thanks for that, one observation though, having observed previous historical data for VIX from SC is that such maintenance periods are not backfilled - is that correct and if yes can that be rectified?
[2024-11-17 17:49:56] |
Sierra_Chart Engineering - Posts: 17133 |
Tell us specifically what data is missing and we will check on this. We know about Friday, November 15, 2024 and we are going to get that from the exchange.
[2024-11-18 12:36:06] |
well u can run a simple timeseries query on your historical VIX timeseries and see the gaps yourself - there is no point in me telling u that because it would be less comprehensive and precise as end user of ypur system and data btw from a system architecture and operation pespective do u accumulate VIX historical data on your SC side / platform or u download it on request from your market data provider on request from the end user each time? |
[2024-11-18 14:13:39] |
also note, after 15th ie now the follwoing Monday - no other CBOE indicies except VIX seem to be received ..... ie still no data for all CBOE indicies after the maintanence day 15th
[2024-11-18 15:11:26] |
TYVIX_CGI - the CBOE 10 year treasury vol index symbol seems to be unknown to the SC Debali Serivce - are u getting data for it at all?
[2024-11-18 17:53:45] |
TYVIX_CGI is not a valid symbol. There is a TYX_CGI symbol, and this is working fine today.
