Date/Time: Wed, 04 Dec 2024 08:55:32 +0000
ADR-SP not working
View Count: 112
[2024-11-15 14:53:33]
the white rabbit - Posts: 22
My ADR-SP chart is not working; however, all other charts work and load fine.
any issue with that specific chart symbol.
thank you
[2024-11-15 15:28:32]
John - SC Support - Posts: 36442
Refer to the following:
US Equities/CFE Data Early Morning Weekday Carrier Maintenance Notification
[2024-11-15 18:48:23]
Gustavo - Posts: 74
Hi, I noticed the same thing and went to the link referenced by John. The last post I see was at 17:17:29. Could I suggest that posts' times be adjusted to reflect something common to most trades? Say, Chicago or NY times? That will help provide us users with a relative timeframe... in this particular case, to know if this post was made before market open, during the morning, at noon, etc. I hope I explained myself... if not, please let me know. Thanks!
Date Time Of Last Edit: 2024-11-15 18:49:05
[2024-11-15 20:07:53]
At the top of the Support Board is a link for "Control Panel" (just below the main title of "Support Board" in with a line of links). When you select that link there are options for how you can view the Support Board.
In particular, for your question, is an item named "Time Offset in Hours". Set this to what you need to see the Board Posts in the time zone you want. The default time is UTC, so Central US time would be -6 hours during Daylight Standard Time.
[2024-11-15 21:25:17]
Gustavo - Posts: 74
Thanks John! Your help is always very appreciated!
