Date/Time: Thu, 21 Nov 2024 13:26:46 +0000
interruption in Live data
View Count: 65
[2024-11-15 14:42:13] |
User788484 - Posts: 25 |
My chart data wont load current day. I went to data limiting and it wont give me the option the update current day. I was receiving live data yesterday.
[2024-11-15 14:44:01] |
Sierra_Chart Engineering - Posts: 17133 |
Tell us what symbol you are having a problem with. Just one symbol only. Also refer to: US Equities/CFE Data Early Morning Weekday Carrier Maintenance Notification Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-15 14:46:32
[2024-11-15 15:14:10] |
Symbol is SPY
[2024-11-15 15:55:43] |
John - SC Support - Posts: 36174 |
Refer to the following: US Equities/CFE Data Early Morning Weekday Carrier Maintenance Notification For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-15 20:15:29
