Date/Time: Thu, 21 Nov 2024 12:40:53 +0000
Custom symbol stopped working 09/27
View Count: 116
[2024-11-14 20:04:12] |
jmftattoo - Posts: 94 |
{VIX1D_CGI}+{VIX1Y_CGI}+{VIX3M_CGI}+{VIX6M_CGI}+{VIX9D_CGI}+{VIX_CGI} custom symbol worked fine until 09/27, then stopped at close of market that day. since has not updated. I have CBOE activated, and have created custom symbol in global settings. what else can i do to trouble shoot why it wont load
[2024-11-14 21:30:34] |
John - SC Support - Posts: 36174 |
Please get us an image of a chart for that symbol by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-15 01:47:50] |
https://www.sierrachart.com/image.php?Image=173163542315.png Chart image Date Time Of Last Edit: 2024-11-15 01:50:45
[2024-11-15 14:44:29] |
What is "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" set to?
[2024-11-15 15:16:44] |
Teton CME Order Routing. |
[2024-11-15 15:27:39] |
it does it on all data streams though, I checked, SC all services, and Trading evaluator, and the output was the same.
[2024-11-15 15:44:09] |
I am now noticing my market internals symbols, like TICK-NYSE_NASDAQ_NYSEMKT are not working either. Same, Teton order routing data. Checked trading evaluator feed as well, and not working
[2024-11-15 15:59:55] |
Refer to the following for why the Market Statistics are not working: US Equities/CFE Data Early Morning Weekday Carrier Maintenance Notification For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-15 16:01:26] |
We would like for you to set the option for "Chart >> Chart Settings >> Symbol >> Continuous Futures Contract" to "None". Let us know if this changes anything for you.
[2024-11-15 16:41:34] |
https://www.sierrachart.com/image.php?Image=1731688862298.png Nothing changes, "Apply all" is pressed, and i see the same exact 09/27 end of data. |
[2024-11-15 19:23:49] |
Please follow the instructions at the following link. In this case, you will want to right-click towards the end of the current data in the chart: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
