Date/Time: Thu, 21 Nov 2024 12:36:58 +0000
Custom Control Bar Name not displayed in Menu
View Count: 56
[2024-11-14 09:34:21]
Benutzer4711 - Posts: 35
Hi
When I customize Control Bar 1 and change its name to "Custom Name Bar", the name "Custom Name Bar" is not displayed when i select the control bar via Window -> Control Bars --> ....
its showing Control Bar 1 ..to .. 12
Is this indented like this?
[2024-11-14 15:12:53]
Sierra_Chart Engineering - Posts: 17133
Yes the name is not going to change on the menu.
[2024-11-14 15:20:11]
John - SC Support - Posts: 36174
The name is used when you have the Control Bar floating. Then that name will show in the title bar for that Control Bar.
[2024-11-14 18:46:11]
Yeah i got you guys - it's just if you have customized 7 control bars with names you always have to find the right one since the default name stays in place.
thanks anyway
