Date/Time: Thu, 21 Nov 2024 12:58:45 +0000
Time LAG on my Clock
View Count: 57
[2024-11-13 21:24:42] |
User616230 - Posts: 1 |
The Time on my charts is one hour behind the current time. How do i rectify this? The clock was working fine not until the most recent renewal. |
[2024-11-13 21:26:23] |
John - SC Support - Posts: 36174 |
You need to set the Time Zone for how you want it. There are two time zone settings - a global one and a chart specific one. The chart specific will be set to use the Global Time Zone by default. Refer to the following: Global Settings Menu: Time Zone Settings (Global Settings menu) Chart Settings: Time Zone (List) (Chart >> Chart Settings >> Session Times menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
