Date/Time: Thu, 21 Nov 2024 13:03:06 +0000
points on stop and limit graphical lines
View Count: 43
[2024-11-13 19:23:28] |
User144295 - Posts: 70 |
Hi team, I was trying to find how to show points on stop and limit graphical lines. So, when I adjust SL or PT so I can see full point on the line. Not just the price. I mean full point from entry price. So, assuming I enter with SL and Limit 20 points. I will move SL 5 points closer to entry price. So I would like to see as I approach closer to entry price, that SL value is decreasing to 15. And then I release the mouse. Thank you for guidance. Date Time Of Last Edit: 2024-11-13 19:25:17
20241113 20 21 55.jpg / V - Attached On 2024-11-13 19:23:19 UTC - Size: 26.14 KB - 16 views |
[2024-11-13 20:23:10] |
John - SC Support - Posts: 36174 |
Set the following setting to "Yes": Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) And in order to see Points in the display, you need to set the "Profit/Loss Format" for each chart as you want. Refer to the following: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
