Date/Time: Thu, 21 Nov 2024 12:50:04 +0000
Graphique bouge
View Count: 42
[2024-11-13 16:57:25] |
User914407 - Posts: 37 |
Bonjour, Mes graphiques bougent de quelques ticks en haut ou en bas lorsque le prix bouge lui aussi de quelques ticks ... |
[2024-11-13 18:27:58] |
John - SC Support - Posts: 36174 |
From Google Translate: My charts move a few ticks up or down when price also moves a few ticks...
This makes sense if your Scale is set to "Automatic" and depending on how the data is displayed. There are a number of other scale options that you can choose from to have the scale act in a certain way. Refer to the information in the following section: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
