Date/Time: Wed, 04 Dec 2024 08:59:08 +0000
Independent Volume Profile - Set to Left Side of Screen. Is this possible?
View Count: 125
[2024-11-13 16:18:56] |
User708541 - Posts: 88 |
I'd like to have a session volume profile that is set to the left side of my screen. The vol profile would adjust it's position if I horizontal scroll my chart and always remain visible. I think setting the volume profile to "Independent Volume Profile for TPO Chart (In:107) is a step in the right direction. But it won't set itself to the left of my screen. Please clarify if I can do this and if so, how. If it's not possible with Vol Profile, can it be done with a Trading DOM on the left side of the chart where everything is removed except a volume profile? Thank you. Date Time Of Last Edit: 2024-11-13 18:53:54
[2024-11-13 20:10:54] |
John - SC Support - Posts: 36442 |
In general, to have a left-aligned profile for a certain period, you setup a Volume by Price study for that period and set the Input for "Always Display Last Profile Within View" to "Yes". But, if you are doing this with a TPO Chart, then you can not have it left-aligned as the option for "Right Align Volume Bars" is forced to be "Yes" due to the TPOs. We do not understand what you mean by "The vol profile would adjust it's position if I horizontal scroll my chart and always remain visible". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-11-15 18:27:33] |
User749040 - Posts: 41 |
Hello John, I'm also interested in this feature. When setting up profiles on the right, they can be stacked next to each other, however when adding profiles on the left, they are inside of each other even with "Always Display Last Profile Within View" set to "Yes" Let me know if you need screenshots. Thank you. |
[2024-11-15 20:00:50] |
There is no support for "stacked" profiles on the left. What we referenced above is for a single profile that you can have displayed on the left.
[2024-11-15 20:08:09] |
Ah ok, is that something you can add? Stacked profiles on the right are very nice but I already have levels/labels on the right side so the left is better if it's an option.
[2024-11-15 20:27:47] |
We have this on our "to-do" list, but the list is very long and we can not say when we would get to any particular item.
