Date/Time: Tue, 03 Dec 2024 17:52:41 +0000
Large Volume Trade Indicator: Indicator not showing
View Count: 90
[2024-11-12 17:15:17]
Kifutures - Posts: 1
I have two charts with Large Trade Volume Indicator with varying Volume Threshold.
One is set to 15 and the other is set to 25.
Somehow, the chart with 15 threshold displays the indicator with 32 but the one with 25 threshold does not.
Both studies are drawn based on Total Volume Above Threshold.
Please refer to the attached screenshot.
imageLVTI.JPG / V - Attached On 2024-11-12 17:08:21 UTC - Size: 536.02 KB - 24 views
[2024-11-12 20:51:20]
John - SC Support - Posts: 36426
What you have to remember is when using the option for "Total Volume Above Threshold" the study is going to find all the trades that are above the particular threshold and then show you the sum of those trades and color the marker based on that sum. So the reason why you are seeing a 32 in the chart with a threshold setting of 15 and not seeing it in the chart with a threshold of 25 is that there were multiple trades that were greater than 15 but less than 25 that make up that total of 32 (such as 1 trade at 15 and another at 17, or two trades each at 16). But since neither of those trades was greater than 25 they will not show up in the other chart.
