Date/Time: Wed, 27 Nov 2024 12:28:59 +0000
Compressed Toolbar
View Count: 1324
[2014-09-09 12:59:08] |
infpz - Posts: 826 |
Any idea how to resolve this? The display settings appear to be normal. And the rest of the text in SC Looks OK.
[2014-09-09 16:23:51] |
Sierra Chart - Max - Posts: 5731 |
Instead of increasing the Font Size within Sierra Chart and Windows, you can increase the dpi settings following the steps here: http://technet.microsoft.com/en-us/magazine/ff629368.aspx In most cases you will not want to go above 150 dpi, unless you have a ratina display. Sierra Chart Support |
[2014-09-09 21:31:13] |
The problem is the system font size in Windows has been increased in size.
