Date/Time: Thu, 21 Nov 2024 12:58:38 +0000
Anyway to use Chart Linking as a way to control the visible charts in an instance?
View Count: 47
[2024-11-11 23:40:54]
knarf01 - Posts: 48
Hi Support,
This is likely more of a feature request.. Let's say I have 4x charts in a chartbook, 2x of those are dedicated to NQ the other 2x ES. But my layout is split where ES Chart 1 is on the left, ES Chart 2 is on the right and NQ Chart 1 is on the left, NQ Chart 2 is on the right. So depending if I have ES Chart 1 clicked it will be visible, but NQ Chart 1 is hidden behind, same with Chart 2 on the right..
It would be great if with the linking function we could magnetize windows so when I click on my ES chart, both ES Charts 1 and 2 come to the forefront, and if I click on an NQ chart, both charts come to the front..
Just an idea for those of use using limited screen sizes and single monitors.
[2024-11-12 15:29:04]
John - SC Support - Posts: 36174
There is no direct support for this. We have set it as a Feature Request.
But, the way to do what you want is to use separate Chartbooks for ES and NQ. That way you switch between the Chartbooks and you will have just those two charts showing from that specific chartbook. Refer to the following:
Chartbooks (Workspaces): To Create a New Chartbook
