Date/Time: Wed, 27 Nov 2024 13:03:33 +0000
ALERT
View Count: 1076
[2014-09-09 08:56:39] |
User28317 - Posts: 149 |
HOW WOULD YOU WRITE A ALERT WHERE THE 16 HULL MOVES ABOVE THE 25 HULL AND THE SLOPE FOR BOTH IS POSITIVE? IS IT POSSIBLE?
[2014-09-09 14:35:55] |
Sawtooth - Posts: 4120 |
Try this: Long: =AND(ID2.SG1[-1]>ID1.SG1[-1],ID1.SG1>ID2.SG1,ID1.SG1>ID1.SG1[-1],ID2.SG1>ID2.SG1[-1]) Short: =AND(ID2.SG1[-1]<ID1.SG1[-1],ID1.SG1<ID2.SG1,ID1.SG1<ID1.SG1[-1],ID2.SG1<ID2.SG1[-1]) where ID1 is the 16 Hull and ID2 is the 25 Hull; edit as needed. |
[2014-09-09 19:28:47] |
In that the alert involves multiple indicators, where would you put the alert? Would you create a study?
[2014-09-09 19:59:06] |
Because you are referencing the studies with their ID#s, you can put each alert formula on any study's Alerts tab, or on the Alerts tab of Chart Settings. You could combine the alerts into one with this: =OR(AND(ID2.SG1[-1]>ID1.SG1[-1],ID1.SG1>ID2.SG1,ID1.SG1>ID1.SG1[-1],ID2.SG1>ID2.SG1[-1]), AND(ID2.SG1[-1]<ID1.SG1[-1],ID1.SG1<ID2.SG1,ID1.SG1<ID1.SG1[-1],ID2.SG1<ID2.SG1[-1])) |
[2014-09-10 04:37:49] |
Here is the documentation for Simple Alerts: https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
