Date/Time: Tue, 03 Dec 2024 17:14:54 +0000
denali feed and interactive broker conection
View Count: 62
[2024-11-11 15:51:58]
User764210 - Posts: 2
Hi i have a live account at interactive brokers but i had issues yesterday to connect and trade the entry in sierra chart and the entry in ibkr was not the same second the symbols was not the same hoe do i solve that i trade stocks so i have denali feed with stock total view with kind regards
[2024-11-11 16:32:31]
John - SC Support - Posts: 36419
With Interactive Brokers, you need to enter the main symbol as what is needed for Sierra Chart, and then set the "Trade and Current Quote Symbol" for what is needed for Interactive Brokers. You will also need to set the option for "Use as Trade Only Symbol" to "Yes". Refer to the following:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
